LG TV on same LAN requires login
Running Plex server on Windows. It is configured that 192.168.0.x is a local lan and login requirement disabled is enabled.
Windows Plex player on 192.168.0.2 works fine. I open player and I go straight to the home screen.
When I open LG Plex player on 192.168.0.78 I am forced to pick a user and provide a pin.
This is driving me crazy. Anyone know how to config LG player such that it either logs in with a selected user/pin OR bypass user/pin completely?
If it works the same as other smart tv’s, once you are logged in, go to the settings from the tv app and enable the Automatically Sign In option.
