pistu
March 18, 2025, 5:44pm
1
Server Version#:
Today, I encountered an unexpected issue, as shown in the image. When I launch the Plex app, I am greeted with the following screen.
WebOS: 04.06.75
LG LF652V
Plex version: 5.4.0
What would be the solution to my problem?
hello. i have exactly same problem, but after AccessDeniedAccess Denied other string
also yesterday all was working fine with Plex
XPlay on same TV working fine
tv LG 55ub850v-zd
plex version 5.4.0
Same error in LG netcast. Last night it was working properly. Thank you!
mbdpet
March 18, 2025, 6:15pm
4
I have the same error message on LG TV. Can you please fix this.
Thank you!
Absolutely the same issue on my LG tv, 47LB731 WebOs1.4
Synology DS216j DSM7.2.2 update 3.
Checking: (About box)
LG C1
Plex app: 5.91.0
Platform version: WebOS 6.5.0
Firmware version: 03.51.16
There was a WebOS update today.
I just installed it and then had to do a full shutdown for it to complete installing.
Given the amount of time required, it seemed like a big update
My DS920 test box is also DSM 7.2.2
i think Your replay it’s not for me as my tv is 2014?
also its need to be something related with plex client on LG as xplay work on same tv without any issues.
also in my case all updates on my tv are set to manual so nothing since yesterday was changed.
Folks:
We’re on this. Think we know where the issue is.
ALL:
It’s fixed.
Please force (hard) restart the app.
Only the older models were impacted. Those of us on the new V2 were ok which is why I couldn’t reproduce it.
Everything is back to normal.
yes, i can confirm issue solved. for me plex back . thanks for fast fix
pistu
March 18, 2025, 9:10pm
13
I can confirm too, it is ok now. Thank you!
mbdpet
March 19, 2025, 8:52am
14
It’s working. Thank you for the quick fix.
