I have a few film titles (most notably the original Star Wars Trilogy) where I have multiple versions.
I’ve seen that I can switch file versions in the LG WebOS app, but rather weirdly, it only shows each variation based on it’s file properties (bitrate etc) rather than the actual filename. This can make telling which version I want rather difficult if they all have similar credentials.
Is there any way (or plans to) be able to choose by file name, or some other method?
As of today you can split those different cuts/editions and treat them as individual items in your library (each with their own poster) – or go through the version selection. As you recognized… the version selector is aiming more at selecting from different available quality version of the exact same video.
There’s a feature suggestion to support handling of multiple cuts/editions in a better way (friendly warning: this suggestion has a long history and lots of different approaches in a very, very long thread )
There’s also a feature suggestion asking to simply improve the “play version” picker
Thanks for that.
Will have a read through that thread.
I have been able to split the files out already using the Windows Web interface, but thought it more practical to select the movie then the version.
Appreciate you can’t please everyone with this sort of thing, but having the option to switch the play version function between file properties and filename would be sufficient to make me happy!
