Librari empty
Hello everyone,
I have problem with mi Plex mediaserver installed on raspberry pi3 with raspbian.
I followed the installation instructions I found here below:
removed link to bad tutorial by mod
Plex media server is running but when I try to create any library I do not see any content in it.
I tried with files in home/pi/Music folder but I see no contents.
I Aldo tried with data inside an external hard drive but Plex does not see any subfolder.
I found many solutions online but none of them worked for me.
Any suggestion?
Thanks in advance
Permissions are not set correctly.
This covers all the steps necessary from the beginning through settings permissions and adding the directories.
Adapt as necessary to your needs but be certain to follow all appropriate steps.
