Libraries auto-collapse --> how to disable?
Sorry for my stupid question but how can I disable the auto collapse of the libraries (hiding the library names and showing only the category symbol)?
After updating to the latest Player version it suddenly was turned on.
Server Version#: 1.24.1.4931
Player Version#: 7.22
I don’t think you can disable the sidebar from collapsing (nor can you get it to completely hide). The latest update brought the Plex for Apple TV client to the same layout as the other apps that already worked this way → the sidebar will only show the library names if you focus it.
OK Thanks!
But please add the name of the libraries to the top of the screen. Because this way I don’t know which library is selected and have to guess their name through the showed media items. :wink:
