I have a Plex Pass subscription and I have a premium music library created. On Android and Roku, I have options for library and artist radio, but I just get an error when I try to play them. Roku tells me there are no selected items and Android tells me media in unplayable.
I’ve made sure that my music tracks are analyzed. I have information for loudness, similar artists and under XML view it guid is not set to local.
I tried to play library radio twice and then a artist radio for 2 different artists. I can see in the logs that it’s generating a playlist of 0 tracks. Just not sure why.
Firewall only active for external connections and not using a VPN.
If you see this part of the log, you can see me try and start artist radio for 2Pac. It actually finds related artists in my library, but doesn’t find any candidate tracks. Not sure what’s going on. Should I just try deleting my music library and starting over?
Aug 21, 2018 21:41:53.819 [0x7f4615ffa700] DEBUG - PlayQueue: 0 generated IDs compressed down to a 2 byte blob.
Aug 21, 2018 21:41:53.839 [0x7f4615ffa700] DEBUG - Radio: Computed 0 candidate tracks for 2Pac.
Aug 21, 2018 21:41:53.854 [0x7f4615ffa700] DEBUG - Radio: Adding similar artist 'Dr. Dre'.
Aug 21, 2018 21:41:53.856 [0x7f4615ffa700] DEBUG - Radio: Computed 0 candidate tracks for Dr. Dre.
Aug 21, 2018 21:41:53.856 [0x7f4615ffa700] DEBUG - Radio: Stepped the radio generator for artist '2Pac' in 16 ms.
Aug 21, 2018 21:41:53.872 [0x7f4615ffa700] DEBUG - Radio: Adding similar artist 'Jay-Z'.
Aug 21, 2018 21:41:53.873 [0x7f4615ffa700] DEBUG - Radio: Computed 0 candidate tracks for Jay-Z.
Aug 21, 2018 21:41:53.873 [0x7f4615ffa700] DEBUG - Radio: Stepped the radio generator for artist '2Pac' in 17 ms.
Aug 21, 2018 21:41:53.874 [0x7f4615ffa700] DEBUG - Radio: Stepped the radio generator for artist '2Pac' in 0 ms.
Aug 21, 2018 21:41:53.874 [0x7f4615ffa700] DEBUG - PlayQueue: Start index: 0 End index: -1 Count: 0
I wouldn’t delete the music library just yet. Quick question… Does this issue only occur when playing Library Radio? If you play the artist song, does that play without problems? Also, I see in the logs it seems you are casting to chromecast. Does it play if you do not cast?
If you look in “Plex Media Server Log” and go to line 10990, you’ll see where I started to try and play artist radio for a few different artists. I then tried to play library radio which also did not work.
So, after a Plex Media Server reinstall (I got new hardware), I am once again trying to get Artist Radio working. I get the same errors as before. Is there something I am leaving out when I am setting up my Music Library? I’m using a Premium Music Library, but am deselecting some of the options.
I did not have “Download Popular Track Information” enabled in my music library. It seems that it is necessary for the server to compute candidate tracks for the playlist.
I checked all of the online documentation for Premium Music Library and the features. This isn’t mentioned as a requirement, and that led to quite a bit of hair pulling.
@ChuckPa, I appreciate you trying to follow up with me and get this resolved.
Thank you for posting this! I’ve spent a couple days now searching these forums, rebuilding the plex library, rebuilding the sql db, uninstall-reinstall etc etc and the whole time it was one check box that should be defaulted on. Brutal.
