Library and empty folders
I have Libraries with folders and videos inside most of them sorted by Folder view.
When navigating in my personal libraries, If I go to an empty folder (you can read “no content”), there is no way to go back to the main library page or Plex Home. The back button on the remote does not work, and the only way to leave an empty folder is pressing the Home in the remote an go to the Roku’s (main) Home page.
If you press Left a few times can you get the main lefthand Home/Library menu?
No, I can’t.
Even the screen is different. The top stripe is not darker and there is no Home icon (and no Plex logo).
That looks like the normal UI. Are you on the UNO UI from the Roku Preview Channel? Either way, it’s a bug one way or the other :slight_smile:
Yes, I just noticed that the dark strip is not there anymore… I liked it dark and it helps visually; but the home icon was a good thing to have there. And the Plex logo, well… that’s is just an aesthetic detail.
However, as you said, the bug is there.
Thanks for the report! I’ve reproduced this and filed an issue internally to fix it.
