In the latest version: 8.4.0.19279
When you enter any library, the library button no longer shows the entire library. It only flashes and stays on Recommended… How can I fix this or how can I download the previous version?
Since you have a Plex Pass you can download whichever you want from the release notes announcements Plex for Android
Is the library loading fine in other apps?
Thanks to your reply I thought to check on another device, it was fine. So ‘Clear Data’ and re-login was the fix (‘Clear Cache’ didn’t work).
Back in action, thanks for the response!
