Library change detection is not working correctly
Server Version#: 1.32.8.7639
Player Version#: 4.118.0
library change detection does not work, plex will not automatically update the library after files are downloaded to the target folder. I have to use every 15 mins scan to make sure my library up to date.
Might this apply ?
Thank you, that fixes my problem.
