Server Version#: DS1815+
Player Version#:DSM 6.2.2-24922 Update 4
Having been running plex happily for a few years with TV and Films Libraries. Library appeared to corrupt itself when using the TV library so uninstalled from Synology, deleted library & reinstalled - Mount address hasn’t changed. Via Plex web app have recreated the libraries - Film detected and recreated fine, TV library won’t detect any of the sub folders with content just sees it as empty. At a loss on how to restore the TV library, I tried creating another shared folder and copied 1 sub folder across and it cannot read it in another share either.
Plex can find TV1, then it cannot find any sub folders underneath - given this worked until yesterday after when the library corrupted am scratching my head a little..
Please check out the post about recent (sort of) changes to the Synology platform… you might need to follow those instructions for Plex to keep properly seeing your content: Plex Media Server security changes for Synology users
Your files are named wrong – at least not in the way Plex likes them to be named (w/ A being the season # and B being the episode #):
your naming: [show name] - AxBB - [episode name].avi
Tom - Appreicate the quick response, I did some checking on the permissions side and it appears when I reinstalled Plex it didn’t permission the TV folder, it did repermission the film folder for Plex with Read
So if anyone else has those issues after a reinstall worth check the read settings have carried forward on the shared drives.
Thanks and can close this issue.
