Library not showing on Plex - Shield
I added a library for TV. I log into the computer and go to my account online. Then to manage library and I can see all of my TV series.
But when I fire up the Nvidia and go to Plex, I don’t see Libraries anymore. The server is running. I am logged in.
Any ideas?
I have a similar issue on Nvidia, to fix it I have to click on server name and choose it again to get it to refresh.
Do you do that from the Shield itself or do you do it from where you logon to your account online?
I don’t see it online is settings and on the shield I can only turn the server off and on which I did.
On the Shield.
I found the server button. I turned it off and then turned it back on. But that didn’t do anything. Where do I “select” it. Go through set up again?
OK - I found were to select it and that worked.
Many thanks.
I notice my server is sometimes turned off. Any idea why it turns itself off?
One user on our server has this problem - we have to login as another family member then back again for the library to show up.
