Library Scan crashing PMS
Server Version#: latest plexpass
Hey there,
after going nuts about my crashing PMS, I came to find that it’s the scan of a certain library (TV Shows) which is crashing my server in 10 out of 10 cases.
If you need any logs let me know
Similar issue here and found that Credit Detection causes mine. If you have that enabled, check it out. I had to disable mine. Anytime I have credits detection enabled my entire machine crashes. End Credits Detection causing Windows Crash (BSOD). Posting here in case they are related as I’ve not gotten any traction on mine.
I already replied in your thread, but I’d like to know - if you don’t mind - which Motherboard you are using? Because I was doing any possible hardware test lately but my PC keeps crashing still and it’s very suspicious, that we both have the 14900K
If you Google around a bit, you may find that Intel is currently in hot water, because apparently this CPU model is not stable when taxed very highly.
You may find a bit of relief by (re-)enabling the power limitations (those which only the “K” models allow to disable) for the CPU in your computer’s BIOS.
I have the MSI PRO Z690-A WIFI DDR4(MS-7D25) motherboard. I wouldn’t expect an issue with the cpu as I’ve tweaked the fans to keep temps around 45C. It does seem like a mini inferno though.
The type of MB doesn’t really matter. It’s a flaw in the CPU itself and the limits it has defined for dynamic overclocking etc.
