Server Version#: 1.23.5.4862
My plex server was able to scan my seed box successfully and pick up all the media there. About a week ago I experienced accessing the plex server from the plex app so I did a reinstall to see if that would fix it. Afterwards my library scans now only pick up one or two series, and will ignore many other series that it was finding before.
I’ve included a few lines from the log file that seem to show some issues in looking up meta data but they’re not showing up every time I run a scan.
I can see on the alerts in the plex server settings that it’s scanning the folders, it’s just failing to find the media which it was able to do before.
This problem doesn’t seem to be happening for movies and is mainly TV series.
I’ve tried moving media files so their in a folder that only has the tv series name in it but that didn’t change anything. I’ve tried updating plex, reinstalling, restarting, deleting and recreating libraries, refreshing all meta data in a library but nothing has worked.
Anyone got suggestions on what to do try next or how to better diagnose the problem?
Plex Media Server.3.log:Jul 20, 2021 22:31:31.640 [0x7fd39c09cb38] ERROR - Unknown metadata type: folderPlex Media Server.2.log:Jul 22, 2021 16:35:08.901 [0x7f2676041b38] ERROR - Metadata /system/agents/media/get request failed with code: 500: http://127.0.0.1:34191/system/agents/media/get?guid=local%3A%2F%2F280&mediaType=4&url=metadata%3A%2F%2Fposters%2F5cb08ed1fca15299ce82b90389d34801fae05847
1 Jul 26, 2021 21:48:11.841 [0x7f66caca7b38] ERROR - Error issuing curl_easy_perform(handle): 7
