So I noticed that the scan of my Movies library was taking forever and if I cancel the scan, it just starts right back up automatically. Should be looking in the PMS log or the Scanner Log?
Well known issue… They’ve been working on it since 1.12.2 was in beta
Grrrrr…that’s frustrating. I can’t do any manual scans because of it.
I’m having this problem too
Also prevents other libraries from updating UNLESS I close PMS, end the Scanner process in Task Manager, then reload PMS and queue a manual scan of other folders. Otherwise it defaults back to Movies and wont let up.
There is an update going through QA now.
If you can (Windows hosts can do this easily) back down to an earlier server version. I believe Windows systems automatically maintain older installer versions.
On Linux, simply install a older pkg fie
@ChuckPA said:
There is an update going through QA now.If you can (Windows hosts can do this easily) back down to an earlier server version. I believe Windows systems automatically maintain older installer versions.
I’m running in docker.
I personally see no option to revert.
