Created a couple of lists with a lot of content,
Now when I try to access anyone of them from my Android mobile or Tablet I get this error: List not found ![]()
Hello, I’ve moved your feedback into it’s own thread so we can figure out what’s going on without disturbing the thread you initially made it in. I hope that’s ok.
Can you walk me through the steps just to make sure I’ve walking the same path? I assume you made these lists on the same device and then wen to access your Lists only to see the error you called out. Is that correct?
I go to: https://watch.plex.tv/sv/watchlist/my-lists when on Windows PC (Chrome browser), and on Android mobile and Tablet with Plex 2026.4.1
I click on one of my newly created lists and on the Windows PC I get: YOU SHALL NOT PASS
I can see all my lists on both my Android devices and on my Windows PC from Chrome browser.
All lists are created by me and are private, some content added from Chrome browser in Windows PC and some from Android Tablet.
Android Mobile and Tablet shows the error: LIST NOT FOUND
Thank you for all the details. Sorry for the confusion and frustration this is causing. I’m escalating this issue to the team to investigate.
Sorry, I forgot to ask. Can you reproduce the error page then grab your mobile app logs? Then share them with me either here or via DM.
I can reproduce it.
Looks like our team understands the issue. This is something in the backend that needs to be addressed. I’ll try to reply again once it’s deployed but chances are you’ll see it resolved before I can response. I do not have an ETA that I can provide unfortunately. Again, sorry for the frustration this has caused and thank you for your patience.
Ok, great you found the issue.
I know it can be tricky to first find an issue, then you must fix it and not F up something else, and last test it before release.
I have worked as a programmer since 91.
Thanks for all help and feedback.
@Mikael_Aberg If I’m reading the issue correctly (I might not be
), this should be resolved for you? Could you double check again that you can seeing and select your Lists?
Hi!
I can access the content of the lists now, but I can’t play any of the movies when I select them, just add them to the watchlist (even if I can select them from my library and play them).
Can you share an example (screenshot)?
The flow to playback should be exactly the same as from your Watchlist. Select something from your List or Watchlist will route you to our Discover detail page. You should see an option Where to Watch. From here you’ll see any available location where you could watch from. Likely, your PMS.
Sorry, but no.
Including some samples pictures
This is when I look and chose in the list (both Windows Chrome and Mobile):
This is So You can see I have that already in the list from my files:
Selecting ADD TO LIST (it is allready there):
Also including a logfile
Share Debug Logs 3.zip (395.0 KB)
So @Atomatth what is happening (some more backend six or what)?
Based on the screenshots, everything looks to be operating as expected now. Currently watch.plex.tv does not have any connections to any PMS. So your PMS won’t be seen as an available source for playback.
On mobile, it looks like your server is showing as an available source.
This
flow would really only exist on mobile, for now. Sorry for the confusion.
Aha, ok, I see, a little far fetched and not so intuitive as I added it from my own media, but I can live with that for now.
Thanks for clarifying
