Hi.
I had problems finding all channels in the DVR-Settings.
I figered out that the supplied scanner is not up to date for my location, so I added the missing frequencies to the scanner.
And see, he can now find all channels that are available in my region
https://github.com/patrick-dmxc/plex-DVR-Scanner-Berlin
My location is Berlin, so for all “Berliner” who have the same problem, this is the scanner.
simply copy the *.ini File into the correct folder, start the station search, select “Kabel Deutschlans / Vodafone, Berlin”, and off you go.
After a few minutes, all channels should be found.
No need to restart the server after adding the file!
