Live TV and DVR Fail - no idea why
Install Plex Media Player today 2019-11-21T05:00:00Z. Installed HDHomerun Prime 3 tuner using the Live TV and DVR install. Seems to have installed properly. Have the right EPG. HDHomerun Prime works using silicondust viewer as well as NextPVR.
When I try to play a live show the server locks up and just shows spinning icon. When I try to record a show shows spinning icon but nothing else and also seems to lock everything up.
Log files included for anyone to look at.
Plex Media Server Logs_2019-11-21_16-54-02.zip (92.7 KB)
Plex Media Server v1.18.2.2041-3d469cb32
You have HW transcoding turned on, which cpu do you have.
[FFMPEG] - Error setting child device handle: -16
Join the fun in:
Thanks for your quick response. I hope to give it a go Friday-will keep status updated then.
Again, thanks for the help - the logs can be confusing (at least to me lol).
Got a chance to try the fix - taking it off using hardware transcoding if available. I’ll be testing it some more soon, but for now - Thanks
