Live TV/DVR transcoder error
Server Version#:1.15.6.1079-78232c603
After my MythTV computer died in a power outage, I decided to see if I could get the DVR functions of Plex up and running. It finds my hdhomerun, was able to scan for channels, and dowloads the guide fine, but I can’t play live tv or record anything. With Live TV, nothing ever shows up and the player eventually exits, and with recordings, it sits there for a little bit (perhaps 30 seconds) and then says there’s a transcoder error. I’ve verified that the transcoder path has permissions and plenty of space, and I’ve searched the forums for similar problems and tried the suggestions I’ve seen, but nothing seems to make it happy. My tuner is a hdhomerun3_atsc which seems to be working fine outside of Plex, I upgraded to the newest Plex version today, and I’ve also tried completely removing Plex and starting from scratch in case there was some odd old config from years ago that I didn’t remember. Any ideas on how to make the DVR work?Plex Media Server Logs_2019-06-09_21-20-54.zip (1.0 MB)
Install the HDHomerun software on a Windows box and do a channel scan, chances are the firmware needs updating.
Is this new install or one that you added DVR to?
Other issues:
Your database has corruption. If just starting out it may be best to purge install and start over. If you used a script to install, some may be out of date.
Your Roku 2 XS is lite on memory and probably won’t work.
You have Plugins installed, they are going away.
Don’t use HW transcoding with that CPU, it has a tendency to crash.
Transcoder it pointing to /tmp - needs at least 16GB of free space at all times for TV
Default install uses Plex user:group, easiest to create a plex user on your storage device with read,write, execute on the TV directory.
Is the custom domain only local? In any case Plex does DNS-Rebinding to plex.direct and your router may be blocking it.
Tiebierius,
Thanks for your quick reply. More info mixed in below…
Indeed, the firmware upgraded from 20110414 to 20170930. It didn’t seem
to affect the problem however.
Both, it was an existing install I had done years ago for the sole
purpose of using a plugin that has since stopped working for multiple
years now. After reading some other forum posts, I did a complete purge
of plex and reinstalled from the current deb, but the results were the
same.
Other issues:
may be out of date.
I tried that from the official deb package with no change. Was there
something in the logs that indicated the fresh install already had a
problem with the database? I can certainly delete everything and try
again if you think it could help; all I’ve done other than trying to do
the dvr setup is point it at some existing movies and music which is
plenty easy to do again.
It seems to load Plex well enough to play movies from the server, but
I’ve been primarily testing with the web client. I have a current
generation Roku buried on my desk that will be replacing the Roku 2 in
the near future.
After I did the fresh install, there should definitely not have been any
plugins anymore; if there was something in the logs that showed a
plugin, then perhaps I missed something when I deleted the old copy. It
seemed like everything was contained in /var/lib/plexmediaserver, but if
something is stored elsewhere, it may not have been deleted before I
reinstalled. If my fresh install wasn’t as clean as I thought it was,
then that seems like the best place to start.
HW transcoding isn’t currently enabled, but that’s good to know. I’ll
be sure to leave it off.
all times for TV
/tmp in this case has 66 GiB free.
This is the library path for TV:
drwxrwxr-x 3 plex video 18 Jun 9 10:15 /srv/nfs/Media/TV
I also double-checked and Plex is indeed running as the plex user.
Plex seems to be properly recognizing the difference between the
internal and external IPs on the network. I don’t currently have a port
forward for Plex in my router for incoming traffic, but all outgoing
traffic is working. Other than TV/DVR stuff, playing other media from
any device I’ve tried seems to work fine, so my current assumption is
that the networking bits are ok enough for now.
     --Nick
I have seen other threads from individuals with HDHR3’s that are also having an issue.
There is an Alpha version that is being passed out for tuning problem with HDHR primes and a couple of Hauppauge’s but I don’t think anyone with a 3 has tested.
As long as your are not seeing any more SQLITE3 missing object messages in the Plex Media Server.log you should not have to reinstall.
Edit: Other HDHR3 thread.
