Live TV Broken when on local WLAN on iOS?
Live TV works beautifully anywhere at home on a number of clients, on the road, etc…
However, if I watch on my iPhone 11 Pro at home on WLAN, it loads for a hot second then poops out. Only until I disable the wireless and hop on LTE only will it work. Is this a known bug?
Server Version#: 1.21.0.3608
Player Version#: 7.9
Tuner Make/Model: HDHomeRun duo
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
Having the same issue on my environment. Cannot watch Live TV streams on the IOS devices when connect on WIFI. Works on cellular connection. All other players in the house, FireTV and AppleTV, work fine.
Recently updated my iMac to Big Sur. PMS running on iMac. Not sure if that is related or not since I have not used the player on IOS for a while.
SERVER Info
Plex Media Server Version 1.21.0.3616
System Software Overview:
System Version: macOS 11.0.1 (20B50)
Kernel Version: Darwin 20.1.0
Boot Volume: Macintosh HD
Boot Mode: Normal
Computer Name: iMac27
IOS Player Info
IOS 14.2 on iPhone SE and iPad ( 7th Generation )
Plex player on IOS Version 7.10.1
Let me know if you need any logs for debug.
Was able to fix this by deleting the Plex IOS app and the re-installing. Once it was reloaded the liveTV stream and everything else works!.
