Live Tv Channel Order
Hi, i’ve taken advantage of the 1 month trial to check out Plex’s DVR support (considering moving away from Emby).
I’ve managed to get Plex to see my VBox Sat Tuners using a proxy as the middle man and the guide and channels load perfectly. I’m now looking at options to change the order of the channels. They are currently in channel number order (Guide numbering rather than the m2u8 file numbers) but as it is a mix of sd and hd its all a bit of a mess.
Is there a way to change the channel order manually? I’ve not found any mention of being able to do this in my searching?
Hello there. I am very interested in your solution to have Plex see the VBox sat tuner, but I am afraid I don’t understand your statement of using a proxy as a middle man. Do you mind elaborating a bit more? I appreciate it!
