Live TV channels won't work on my Android client
Server Version#: 1.32.5.7516
Player Version#: 9.31.0.3817
Weird problem. On my Android client, I can play pretty much any content available on my server, with the exception of live TV streams. I click on them, nothing happpens. If I pull up the pop-up and say “watch”, still nothing happens.
However, if I use the web-interface, it works fine. If I do the same task on iOS, it works fine. Only the mobile Android client.
How would I go about trying to figure out how to fix this? I’d love to use the Android client as my screen is much bigger.
Thanks in advance.
Server version 1.30.0.6486 Synology
Android Player Client 10.0.0.4149
I am having the similar problems only when trying to connect to Plex live tv from the mobile app. I am getting error " The serve is not powerful enough to convert video" Plex channels do work with the windows client.
I just saw on another post that daylight saving time change causes this bug every year, and looks like it’s happening right on time this year as well! PLEX COULD YOU PLEASE FIX THIS YEARS OLD BUG???
