Live TV Channels?
Does anyone know why channel 2.3 isn’t listed on PLEX?? The channel is called Dabl and it’s got some interesting shows.
Plex does not carry any channels. That channel is depending on the local market that you are in the USA. According to wiki “ As of September 2019, Dabl has affiliation agreements with 120 television stations in 106 media markets (including all of the 25 largest markets) encompassing 39 states, covering 73.22% of all households (a potentional reach of 228,783,691 viewers, with at least one television set in the United States.[1]”
Not every market may get that channel. Results may vary depending on your scanning of the antenna that you have connected to your tuner. This is not something that Plex has control over.
Edit: if you feel you aren’t getting all channels in your market, double check the direction of where your antenna should be facing in order to receive Dabl. You can check https://www.antennaweb.org/ to see where your local tower transmissions are coming from for the local station carrying the signal for Dabl.
Thank you so much for the information! The site & videos were very informative. I passed them on to my techie daughter.
