Live TV crashes when paused and rewound
Running an unraid docker server Version 1.18.4.2164. Shield is newest Plex pass update. I have two other shield pros with the new Plex pass update and two rokus with both stable and Plex pass versions. They all have this issue for over 3 weeks now. I tried disabling transcoding live tv but that didn’t change anything. I power cycled everything and I am running two HDhomerun Primes. With Fios.
The issue is when I pause live tv and then resume it, it often crashes the stream and I have to go out then back in. If I pause it, then try to rewind it crashes the stream. This happens every single time. It happens on my rokus too. I attached my shield logs and my server logs. Most recently happened about 10 minutes ago.Plex Media Server Logs_2019-12-24_11-21-32.zip (5.9 MB)
shieldlog.zip (106.9 KB)
Edit: Looks like web and iOS clients work fine. I checked Roku again and its working now. So looks like just the shield is having this issue!
