live tv disappeared on Nvidia shield??
this evening on my Nvidia sheild, the live tv section has disappeared? and tv programmes section appears to continually load with nothing happening? on the nvidia server via web my dvr is visible? not sure what’s going on? been getting lots of issues with connecting to cloud too. I just checked nvidia server using Android phone and dvr is working, but section on Nvidia sheild still not there?
I know this is old bit I’m getting desperate and not getting much help from Plex. Did you ever figure out a solution to this problem? I’m having the exact same issue.
Same problem here…any updates?
Mine disappeared this morning as well. I run two different servers both with tv and neither are showing the live TV options anymore.
Can confirm that live tv shows up on my fire TV and on the web interface.
Same issue here as well. Have Shield TV, Plex app is updated and Server is up to date. Everytime I open up Plex app I can see Live TV option for a sec then it disappears. I Restared server and Shield. Showed up again for a bit then disappeared again.
My problem ended up being a bad port on the switch my HDHR was hooked up to. I changed ports and it is working fine now. Plex on nvidia shield seems more sensitive to this issue than other devices. It was working on everything but my two nvidia shields. Try changing cables, switches, ports, etc and make sure you don’t have the same issue.
Interesting. I too have this problem. I can watch live TV on the PC running my server and also from my phone but the Live TV option appears at startup and then quickly disappears on the Shield.
Anyone have ideas on this? HDHR is available on the network to other Plex clients so it isn’t a port issue.
I noticed when I shut one of my servers down then I was able to see TV as an option again on my shield tv
I’m having this same problem, when plex opens Live TV briefly shows up and then disappears. HDRM works on LiveTV and the HDhomerun app.
Same as above. I have one server on my Mac, one on my Diskstation, and one on the shield. Only the shield stays "visible ". Turned off the two other servers, unplugged my network switch and switched around the ports. Restarted the shield, and again, it was there for a nanosecond. Then poof, it’s gone! ¯_(ツ)_/¯
I honestly think it’s this shield. No problem on my Fire tv. Side note, on the shield the HDHomerun app pixelates (through any app) but plays fine on fire tv, Mac, tablet, and phone.
There us a bug with the latest Android app where if you have more than 1 PMS, the Live TV option disappears. We are looking into this.
Thanks, is there any update on a fix?
We released a beta with the fix. Waiting for feedback before it goes live to everyone.
I have SHIELD Android TV and user this as server
( 1.13.3.5208-20455f518 )and client.
( 7.1.1.5878 )
No Live TV from shield or Mobile ( Samsung 7 ) Clients.
Live TV Ok on Shield server via Web browser on PC
I have test server on NAS:-
Live TV Ok from test server
MYCHOICE-NAS
1.13.1.5063-b4605f76e
Plex Media Server
PC
Linux 4.2.8 (#1 SMP Mon May 28 01:16:39 CST 2018)
Updates
Nvidia Shield server Version 1.13.4.5251
Client
SHIELD Android TV 7.1.1.5878
Live TV not visible
Live TV Still OK on NAS
Client on samsung S7
7.1.1.5878
Live TV shows for NAS Nothing for Nvidia Shield server
PC Web client OK for Live TV on NAS and Nvidia shield servers
( NAS Version 1.13.1.5063 is old format Guide as I have not updated this )
Update to NAS server Version 1.13.4.5251
Live TV now with new guide on PC windows client
client on Nvidia shield for NAS as server guide is OK but old format
but using Nvidia shield as server NO Live TV shows.
Update
Servers
My SHIELD Android TV 1.13.4.5251-2e6e8f841
MYCHOICE-NAS 1.13.4.5251-2e6e8f841
Galaxy S7 Edge Client 7.2.1.6015
Live TV for NAS OK NO Live TV for Shield
SHIELD Android TV 7.2.1.6015
Observation:- On occasion at First load Live TV appears for a couple of seconds as menu populates
If you are super quick you can open and view OK
once gone from menu cannot get back to live TV
I was having this issue as well as serious performance problem with the Shield in general. I disabled IPv6 on the Shield and so far everything seems right with the world again.
IPv6 I have OFF
Problem is Live TV menu is missing on Shield client and Andoid Phone Client when using Nvidia Shield server but visible if I connect to Server on NAS ( Qnap )
