Server Version#: 1.23.6.4810
Player Version#: Amazon Fire, Roku or Windows Plex Media Player
Tuner Make/Model:
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
Live TV & DVR is no longer accessible, regardless of whether the client app is local or remote.
We can’t help you unless you post more details.
What do you need?
All Live TV & DVR clients locally and remote are now experiencing the same error out of the blue, with local hosted content unaffected.
I just dealt with this, force a refresh of the guide while in the server settings through a web browser.
Forcing a rebuilding of the guide on the server now. crosses fingers. Just hope someone at plex doesn’t think that this is a normal process
Yikes, this rebuilding is taking quite awhile. Even if this works, changing the format like this out of the blue doesn’t seem like the best plan
@Rayven Thanks for the suggestion, but looks like something else is afoot. Going to reboot the router, server and clients (including cache) and simply hope things return to normal.
Well this was a fun ride. @Rayven was on point, starting with the server guide rebuild. At least in my case, I also had to delete the plex data/cache from my firestick to get things working again.
No problem, glad I could point you down the right path to figuring it out, even if it was just a small stepping stone to the fix.
