LIVE TV not working
Server Version#: Latest
Player Version#: Latest
Tuner Make/Model: HDHomeRun
Guide/Lineup name: FioS
Using XMLTV?: DUNNO
Channel number/Name: ALL
I just realized that LIVE TV is not working. The channel guide even though i’ve refreshed it, power cycled the HDHomerun, made it sure it’s on the latest firmware and that the channel guide was updated. I even backed up my plex files and uninstalled and reinstalled Plex Server. I still can’t get channels to appear or LIVE tv to work. None of my DVR recordings are getting recorded either it seems. What should i do?
Update 11/14/2024 FIX: After deleting and re-adding my DVR in Plex settings, everything returned to normal. Although Plex warns that you may lose scheduled recordings, I didn’t lose any. I had also deleted and re-added my TV Shows folder, based on advice from someone with the same issue. If deleting the DVR alone doesn’t resolve the problem, try deleting the TV Shows folder first, then re-add the DVR.
I recently have the same error. Seems the latest update 1.41.1.9057 broke Live TV & DVR. Rolling back temporarily fixed my issue, but today PMS can’t tune, nor show guide data.
HDHomerun is working fine outside of Plex, so it’s clearly a Plex Live TV issue
I am also having this issue with the latest build on my mac plex server. HDHomerun app works fine.
leaving solution here as a post incase its missed in my original:
