Hi I’m living in Ireland and I’ve been thinking about cutting the cord i.e leaving Sky Ireland. I currently have my plex media server setup on my QNAP Nas. I’d like to to now buy a plex pass subscription and setup livetv-dvr. I’d really like to integrate DVB-T2 and DVB-S2 onto one epg. That would be Saorview and freesat uk for me. I already have both aerials installed on my house. Has anyone successfully achieved this and if so can you recommend a tuner for me. Thanks in advance.
Not sure about both at the same time, but here are the officially supported Plex tuners.
J.
I am pretty sure that two different networks do not work with Plex and DVB-S is not officially supported at all.
You have to find your own way through this, with additional tools like tvheadend or NextPVR (cheers @JCHH) . That might work in the end, but will probably also need a source for the EPG then.
Good luck, seems like a longer journey.
Such a pity plex doesn’t support DVB-S. I might buy a dual freeview and freesat tuner and hope in the near future plex will support Freesat in a server firmware update. I may look into Tvheadend and Nextpvr. Thanks @Coxeroni for your reply.
Thanks for your reply @JCHH
