Live TV - DVR locatoin needs changing and I cant
Hello All,
I had my Live DVR working great. I had selected a local HDD for DVR recordings and all worked great.
I then added network shared HDD with home movies (network drive connection) to watch with family and then noticed that my Live DVR now defaults there to put its recoding’s.
My problem is:-
There is NO option to change Live TV DVR locations. - I NEED TO CHANGE THIS
I don’t want to put my live TV recordings in to my home movies gfold.er.
It all goes back to normal if i remove the home movies and DVR folder and re-create the DVR folder. BUT as soon as i add my home movies folder the problem comes back.
Server Version#: 4.108.0
Tuner Make/Model: WinTV Solo HD
Yes, there is.
Edit your recording jobs under Live TV - DVR Schedule
You can decide for each recording job separately where to store the recorded files.
The last selected location will become the default for new recording jobs.
Depending on what classification the recorded item has (Movie or TV Show – depends on the EPG), only libraries of the appropriate type are offered as storage location.
https://support.plex.tv/articles/categories/features/live-tv-dvr/
