Live TV & DVR Settings Failure
Server Version#: 1.25.2
Tuner Make/Model: HDHR Connect Duo & YAP
Using XMLTV?: Yes
Let me just say, anyone looking to put down some vitriol at the setup won’t be helpful. Getting back live tv even with just antenna is my goal.
I’ve got the server running on a QNAP TS-877. My live TV setup was with an HDHR Connect Duo and a Yet Another Proxy fork in a Docker mimicking another HDHR. As two tuners both got their data from XML.
I upgarded the server to 1.25.2 today. After upload no channels from either tuner play on clicking from Guide.
Going to settings and Live TV & DVR brings up an error message:
“There was an unexpected error”
So I can’t even delete the YAP tuner or otherwise make adjustments to the tuners.
I’ve restarted the server without luck. I’ve restarted the server without YAP running without luck.
Maybe just rolling back the server? Where could I find old qpkg version? Or a way to just roll back apps within QNAP? Other ideas?
Logs available.
com.plexapp.system.log (49.1 KB)
Same as me
Everything works again this morning
I have had the exact same problem following updating , did the problem clear itself ?
Any tipis for fixing this would be most gratefully received
Bueller? Bueller?
Plex staff?
I love there’s no way to email/contact for support anymore fo rtechnical issues. Just pray someone responds to your post.
Same problem. Been digging through forums trying all sorts of stuff. No love.
