Live TV Stopped working
Server Version#:1.30.0
Player Version#:Version 1.109.0.329-ea562b95
Been using LiveTV with HD Homerun connected to a QNAP 252 running Server 1.30.0 successfully for several months. Remotely accessing the server over the Internet using a variety of clients including the Android App, Android TV app and PC (Windows App) all OK.
Suddenly stopped working giving the whirly wait wheel then an error ‘The Live Stream has ended’ and not sure what to try.
Tried updating to latest version, same result. Tried rebooting and reinstalling everything - no joy. Odd thing is that all programs show up properly in the program guide, the tuner definitely tunes to the correct channel when commanded. Also pre-recorded TV Shows and Movies all work fine, so do Plex ‘live’ channels, so it’s not a connectivity or bandwidth problem.
Same here. Plex live tv will hang, then go back to the channel guide. Running a ONN 4k pro
Interestingly, seems to work on a old fire stick tv
Started happening after the last QNAP plex server update
