Server Version#: 1.41.1.9057
Player Version#: 10.23.0.1627 (f8f7bc73)
Tuner Make/Model: xTeve 2.2.0
Guide/Lineup name:
Using XMLTV?: Yes
Channel number/Name: Any
Hi folks,
I’m having trouble running the LiveTV on my Google TV Chromecast. The streams are working well for a few minutes and then I get the following error (sorry it’s in French):
Une erreur s’est produite lors de la tentative de lecture de cette vidéo. Veuillez vérifier votre connexion et réessayer.
If I play the stream again it works well for a few minutes and then same error.
I managed to get some logs of the error if it can help:
Nov 03, 2024 09:44:03.947 [139776915671864] Debug — [Req#280c5/Transcode] Found session GUID of 97f8a9af81b99115-com-plexapp-android in session start.
Nov 03, 2024 09:44:03.948 [139776915671864] Debug — [Req#280c5/Transcode] TranscodeUniversalRequest: using augmented profile Android
Nov 03, 2024 09:44:03.949 [139776915671864] Debug — [Req#280c5/Transcode] Downloading document http://127.0.0.1:32400/tv.plex.providers.epg.xmltv:18/metadata/tv%2eplex%2exmltv%3a%2f%2fepisode%2XXXincludeBandwidths=1&offset=-1&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=XXX-com-plexapp-android
Nov 03, 2024 09:44:03.954 [139776915671864] Verbose — [Req#280c5/Transcode] It took 0.0 sec to serialize a list with 1 elements.
Nov 03, 2024 09:44:03.954 [139776915671864] Error — [Req#280c5/Transcode] MDE: No part decision to choose from
Nov 03, 2024 09:44:03.954 [139776915671864] Debug — [Req#280c5/Transcode] MDE: received PLEX_PROTOCOL_ANY from client, but could not determine best protocol. Defaulting to HTTP
Nov 03, 2024 09:44:03.954 [139776915671864] Debug — [Req#280c5/Transcode] MDE: analyzing media item 3552
Nov 03, 2024 09:44:03.954 [139776915671864] Error — [Req#280c5/Transcode] Streaming Resource: Cannot make a decision because either the file is unplayable or the client provided bad data
When playing the same stream at the same time on the web client, the stream cuts out as well with the following error:
This live TV session has ended
Can I get some guidelines of what I should look for and if there are any known issues regarding this ?
