Live TV Freezing - Direct Play Nvidia Shield
Server Version#: 1.19.2.2737
Player Version#: 8.0.0.17276
Tuner Make/Model: HD Homerun Prime
Guide/Lineup name: Atlantic Broadband Montville Digital
Using XMLTV?:
Channel number/Name: All
Shield Logs.txt (1.2 MB)
Plex Media Server Logs_2020-05-01_15-30-32.zip (5.1 MB)
Live TV seems to freeze and stay locked on a single frame after watching for about and hour or so. Only seems to happen on shield, but that’s really the only device I watch TV on for an extended period of time. Haven’t had it happen in web. Not sure if it’s related, but it is direct playing with audio passthrough.
Same issues here. Before a few months ago, LTV was working great on my shield. Then there was the update that really broke it where it was a black frame. Now, after about an HR or so of watching, the picture will just freeze. The app and should remain responsive.
Same.
Hi all :wave:
Thanks for raising, this looks similar to: Live TV stops playing at minute 03 of every hour - #32 by ERoze
Just to let you know I am working on fix :slight_smile:
