I can run live TV through the Plex app on my Roku stick, but when I click on the program guide and then select a show…
1). Sometimes it says that live TV cannot be started
2) sometimes it plays for a few seconds (less than 1 min) and then goes to a black screen that says recieving…basically a buffering screen, but can’t fully buffer and start playing again. It doesn’t get past about 34% and after about a minute or two, it says “Playback Error. Sorry, we could not play your live TV channel.”
Given enough time, when I come back and try again it may work. But usually ends up with #2 above.
I am using OTA with a silicon dust duel. WiFi is very strong, I don’t have issues with other apps/streaming. Server was checked and no updates available. Can pull live TV from other apps using the same silicon dust device, including mythtv.
