Live TV limit of 90 minutes
Has anyone noticed or reported that since the last few updates, you can only watch 90 minutes of live tv on the same channel before it starts an endless loop of a couple second rewind and play? Changing the channel will reset this but often if you go back to your original channel, it will begin at the beginning of the buffer (90 minutes ago).
This happens to me too. I think it is related to a upper limit with time shifting live tv. Plex please fix this.
I noticed this is happening with even less time than 90 minutes. Trying to figure out if this is a server problem or an android (ShieldTV) problem.
Having the same problem. Can almost set my watch by it 1 Hr 30 Min. Using ShieldTV with HDHomeRun Tuner and Plex Media Server on dedicated PC. Only way I have found to deal with it, exit Plex and restart the App.
I keep wondering if the buffer that is used so we can pause Live TV is filling up and isn’t programmed to go back and start all over, so restarting the app clears the buffer…just a thought.
This beta build fixed it for me
Thank you, I’ll take a look
