Server Version#: 1.21.3.4021
Tuner Make/Model: Hauppauge WinTV QuadHD PCIe
Guide/Lineup name:
Using XMLTV?: Y
Channel number/Name: 30.1 and 61.1
I have Plex running in a docker on Unraid. Previous to getting Plex to use the tuner, I checked and adjusted signal strength with the WinTV app and then also mapped channels with tvheadend. I then disabled tvheadend and had Plex tune channels. It is finding all the channels EXCEPT the ones with the best signal strength which are 30.1 (572MHz) and 61.1 (590Mhz) here in CT. Logs attached. Please note I was able to stream both of these through tvheadend.
plex logs 2020-02-16-18-57.zip (311.2 KB)
