Server Version#: 4.116.1
Tuner Make/Model: HDHOMERUN
Guide/Lineup name:
Using XMLTV?:
Channel number/Name: Any Channel
If I set the server to transcode to memory with /dev/shm. Everything works just fine and uses memory except for Live TV.
Live TV will record just fine, but if I try to watch a channel live it is unable to start the channel. If I disable memory transcoding Live TV will work again. Any suggestions.
LOG
Sep 30, 2023 14:27:12.973 [139646763666232] ERROR - [Req#46c4b/Grabber/5fc76df44454ec002d32327f-5fc705dd7c6557002ee1e556-tzdr42lou1l3xbjii7mgt85k] Failed to start session.
Sep 30, 2023 14:27:12.973 [139646763666232] ERROR - [Req#46c4b/Grabber/5fc76df44454ec002d32327f-5fc705dd7c6557002ee1e556-tzdr42lou1l3xbjii7mgt85k] Recorder: Unable to create transcode session or session failed to start.
Sep 30, 2023 14:27:12.974 [139646763666232] ERROR - [Req#46c4b/Grabber/5fc76df44454ec002d32327f-5fc705dd7c6557002ee1e556-tzdr42lou1l3xbjii7mgt85k] Recorder: Error 16 (Recording failed. Please check your tuner or antenna.) starting the record, shutting things down.
Sep 30, 2023 14:27:12.974 [139646793120568] ERROR - [Req#46c4b] Subscription: Rolling media grab failed to start.
Sep 30, 2023 14:27:12.975 [139646763666232] ERROR - [Req#46c4b/Grabber/5fc76df44454ec002d32327f-5fc705dd7c6557002ee1e556-tzdr42lou1l3xbjii7mgt85k] Starting media grab failed.
