Live TV problem
I have an HD antenna hooked up to HDHomeRun Quattro accessed via live tv (with Plexpass).
Via Plex a live program will start but, after a couple of minutes, it stops with a message “cannot play at the moment. Possible weak signal”. If I then try the same program via the HDHomeRun app it will play fine.
The Homerun configuration tool shows strong signal. What gives?
