@bubbapaul said:
HI I am having the same problem
Setup
FreeNas 9.10.2
Plex 1.9.3
HDHomerun 20170815
I cannot watch live tv nor record
When I try and watch live TV I get the error Shaka1001
When I try and record I get “unknown error”
I know that the HDhome run is working because I can use Plex on my shield and watch live TV and record no problems. I get these errors when I try and run the PMS on Freenas.
Also fyi when I try and run http://192.168.0.100:5004/auto/v702 I get ERR_CONNECTION_TIMED_OUT
thx for any help
Yes there are timeouts on requests to the DVR.
Sep 30, 2017 14:37:10.423 [0x80dc82000] ERROR - [Transcoder] http://192.168.0.100:5004/auto/v991: Operation timed out
I see you are actually running on 1.8.4 and not 1.9.3 as you indicated
Sep 30, 2017 14:37:01.918 [0x80a007000] INFO - Plex Media Server v1.8.4.4249-3497d6779 - FreeBSD PC amd64 - build: freebsd-x86_64 freebsd - GMT -07:00
Could you try again with 1.9.3 and go through setup again.
Also I notice there is no Plex Tuner Service.log and there was an error on attempt to start the process
Sep 30, 2017 14:37:04.819 [0x80ad6bc00] DEBUG - Plex Tuner Service starting.
Sep 30, 2017 14:37:04.819 [0x80ad6bc00] DEBUG - Job running: '/usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Plex Tuner Service' '/usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Resources/Tuner/Private' '/usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Resources/Tuner/Shared' '1.8.4.4249-3497d6779' '32600' '/waitmutex'
Sep 30, 2017 14:37:04.825 [0x80ad6bc00] DEBUG - Plex Tuner Service exited.
But 2nd attempt did not log it exiting
Sep 30, 2017 14:37:04.927 [0x80ad6bc00] DEBUG - Job running: '/usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Plex Tuner Service' '/usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Resources/Tuner/Private' '/usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Resources/Tuner/Shared' '1.8.4.4249-3497d6779' '32600' '/waitmutex'
Could you see if there are any tuner service logs in /var/db/plexdata/Plex Media Server/Logs
Also check for disk space - in case
