Watching 1080i channels (CBS and NBC) I noticed this morning that after 10 minutes or so the smoothness is gone and frame skipping or dropping is evident. Something that messes with the cadence, that’s all I know. In Plex this is with resolution switching on or off.
I’ve also noticed this with live channels using via the TVIRL app which uses my dvblink backend. So, this is with two different backends (Plex and dvblink) but both apparently use the Shield TV’'s built in video player.
I’m using the 5.2 experience preview. Could this be a bug in the 5.2 preview?
Of note, SPMC using mediacodec surface with the dvblink backend does NOT have this problem.
Go into Settings and enable ‘Network Logging’ then you’ll see a URL on the bottom. Open that url in a browser, copy the contents to http://gist.github.com or pastebin.com and link the file?
Thanks!
I sent you a message with the link to the log on github
Same issue here. Also the Live Channels app do have this issue on the Shield and exoplayer. VLC works fine with 1080i.
Only interlaced streams are affected. 720p channles are fine. This issue exists since the release of the Shield when you use the exoplayer and interlaced streams.
Thanks for that info. I’ve never extensively watched using exoplayer/live channels. It’s always been a Kodi variant until now.
But resolving this long outstanding issue would be amazing.
But it sounds like here is the wrong place to bring it up? I have mentioned it in the experience 5.2 preview hidden thread. Any idea why Nvidia have not fixed it already?
Bring it up here is a good place. Plex is working together with NVIDIA. Hopefully they can open a ticket at NVIDIA with this issue.
All Shield TV users with interlaced (e.g. 1080i) streams are affected. The Live TV experience is very bad after ~15 minutes. I would say, it is not usable. That is the reason why our household is not using Plex Live TV and we are still using Live Channels (with the workaround in the apps).
The Live Channels apps (Tvheadend & RoboTV) workaround -as the name says- is only a workaround and not a solution. Every 13 minutes you still have a short stutter for 1 second when the renderer would be restarted. On live sports it is acceptable but not really beautiful.
This big issue needs to be fixed by NVIDIA or ExoPlayer itself.
To reproduce it. Get a 1080i stream/file and wait ~15 minutes
