Live TV stopped working after 1.18.3
Server Version#: 1.21.1.3759
Player Version#: Roku 6.7.4.6764
Tuner Make/Model: HDHomeRun Prime
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
Ever since server version 1.18.3, my LiveTV has stopped working on my Roku client. I see the guide from my cable company, which is current, but when I try to go to a channel, I get “Live TV playback could not be started” I have also tried the latest server version 1.21.1.3759 and get the same results. The HDHomeRun Prime is working fine. If I downgrade back to server version 1.18.1.1973 it works fine but now that the clients require 1.18.3 or higher, I’m stuck.
Anyone got any advice on a solution?
I may be having a similar issue. Does the Live TV work on the Plex app for your phone?
Doesn’t work on the phone app either. Very frustrating.
I have the same problem since upgrading to a version with the new EPG. I’m currently running PMS Version 1.21.1.3842 on macOS with an HDHomeRun Prime.
[Update 2021-01-07]
I had to delete my entire Plex setup to get Live TV and DVR to work again. #fail
