Server Version#: 1.30.0.6486
Tuner Make/Model: HDHomerun Extend
Guide/Lineup name: Jeopardy
Using XMLTV?:
Channel number/Name: 32.1 YES Tv
Live TV will stop and buffer, then resume at a point approx 1 minute prior to the point where the buffering started. When the playback reaches the same point where the buffering started, the playback will stop, and the “spinning wheel” will show for approx 2 minutes before the message “Cannot reliably playback this channel, it may be due to a weak signal”
This only happens on one Sharp TV with built in Roku streaming. I have three other sets, all using Roku sticks, that do not exhibit this problem. Other sets can be playing the same feed at the same time and only the one TV with built in Roku will have the problem. This happens daily, for about the past three weeks. It can happen on any channel.
DVR recording is not impacted, and playback of recorded shows is fine. The WiFi router is located within 3 feet of the TV. Signal strength shows as excellent.
I have attached server logs taken immediately after the problem happened. The buffering was at approx 7:32pm on Jan 10, 2023.
Plex Media Server Logs_2023-01-10_19-39-04.zip (6.2 MB)
