Live TV TVR stopped working with Playback Error Source is unavailable
Server Version#: 1.26.0.5715
Player Version#: 1.44.0.2981
Tuner Make/Model: WinTV QuadHD
Guide/Lineup name: Freeview
Using XMLTV?: No
Channel number/Name: All channels
2 days ago, Plex was working fine. I was able to stream live Freeview UK TV to all devices from my Windows 10 home Theatre PC running the Plex server and using a WinTV QuadHD tuner card. When I got home from work yesterday, all Plex functions were working except Live TV/DVR. Every time I access any channel in the lineup, I get the Playback Error message saying Source is unavailable.
I have rolled back Plex, checked the tuner card is working using another app, deleted and re-installed the DVRs, rebooted everything, and tested that I get a good antenna signal.
Is anyone else having this issue?
hi mate
you are not alone
i’m having the same issues and i’m using the hauppauge wintv quad hd
lasted server latest clients latest hauppauge drivers ( i don’t keep wintv installed )
i need to restart the server to get it to work
when changing channel i get the same message 2 o 3 times before actually getting a feed
and sometimes it just won’t tune any channels on any clients ( even shield pro ) unless restarted .
u had any luck troubleshooting this ?
Same here winTVQuad. I have the server restarting every twelve hours As I’m tired of having to manually restart it.
