Updated to the most recent server, Version 1.16.1.1246, and now I can not access live tv on any iOS, apple tv, or web client. It says they are unavailable or unreachable. I can only access on my Roku TV. Was able to access yesterday but today no.
I see the same issue on my iOS device and reported it in another thread. No response yet from dev team
Same issue here
I had the same issue on IOS where it wouldn’t even load the Live TV & DVR hub several times, but then it suddenly started working. Seems to still be working.
Yes also was stuck for a few hours then worked
I’m having the same problem. I can view LiveTV in a browser on my PC, but none of my iOS devices work. The server is “currently unavailable”. The weird thing is that I can watch any other content (TV/movies) on those same iOS devices without an issue.
As a workaround, if you uninstall the iOS or tvOS app and reinstall it, it appears to resolve the issue. I was having the same symptoms of not being able to connect to the Live TV & DVR, but all other libraries were accessible.
I tried to log out/log back into the app, restart the app, restart the server and nothing would work.
I finally uninstalled and reinstalled the app and signed back in and voila! the Live TV & DVR were back… Not an ideal, seamless, transition to the new EPG provider, but at least I’m back up & running…
Thanks for the tip. Uninstall/re-install works.
