Still seeing this. Seems to happen when I’ve been watching something on one Plex client, an iPad in this case this morning. Then I stop my stream from that channel. Then I try to tune into another channel afterwards from that same device. I’m seeing all kinds of good stuff in the Plex Media Server log at this time too…
Jul 03, 2018 12:28:17.895 [39392] ERROR - DVR:Recorder: Error 3 (The recording was aborted) starting the record, shutting things down.
Jul 03, 2018 12:28:17.895 [39392] ERROR - DVR:Grabber: Starting media grab failed.
Jul 03, 2018 12:28:18.114 [33164] ERROR - ClientProfileExtra: video transcode target already exists for streaming hls
Jul 03, 2018 12:28:18.114 [33164] ERROR - PlexClient::downloadContainer: expected MediaContainer element, found html
Jul 03, 2018 12:28:18.114 [33164] ERROR - TranscodeUniversalRequest: unable to get container: /?includeBandwidths=1&offset=-1&X-Plex-Session-Identifier=843CD304-D644-4F1E-BE3F-2C18D4C8F63B
Jul 03, 2018 12:28:38.172 [46068] ERROR - ClientProfileExtra: video transcode target already exists for streaming hls
Jul 03, 2018 12:28:38.172 [46068] ERROR - PlexClient::downloadContainer: expected MediaContainer element, found html
Jul 03, 2018 12:28:38.172 [46068] ERROR - TranscodeUniversalRequest: unable to get container: /?includeBandwidths=1&offset=-1&X-Plex-Session-Identifier=843CD304-D644-4F1E-BE3F-2C18D4C8F63B
Jul 03, 2018 12:28:44.967 [34236] ERROR - DVR:Recorder: Error 3 (The recording was aborted) starting the record, shutting things down.
Jul 03, 2018 12:28:44.967 [34236] ERROR - DVR:Grabber: Starting media grab failed.
Jul 03, 2018 12:29:15.913 [28516] ERROR - Couldn't delete the file "E:\Temp\logs.zip9c19be05-76b8-4fd0-a961-591d01307885": The process cannot access the file because it is being used by another process
Jul 03, 2018 12:29:15.913 [28516] WARN - Could not delete file "E:\Temp\logs.zip9c19be05-76b8-4fd0-a961-591d01307885" after connection reset
Jul 03, 2018 12:29:44.953 [56232] ERROR - DVR:Recorder: Error 3 (The recording was aborted) starting the record, shutting things down.
Jul 03, 2018 12:29:44.953 [56232] ERROR - DVR:Grabber: Starting media grab failed.
Jul 03, 2018 12:30:44.954 [34236] ERROR - DVR:Recorder: Error 3 (The recording was aborted) starting the record, shutting things down.
Jul 03, 2018 12:30:44.954 [34236] ERROR - DVR:Grabber: Starting media grab failed.
Jul 03, 2018 12:31:44.956 [15692] ERROR - DVR:Recorder: Error 3 (The recording was aborted) starting the record, shutting things down.
Jul 03, 2018 12:31:44.956 [15692] ERROR - DVR:Grabber: Starting media grab failed.
Jul 03, 2018 12:32:44.957 [56232] ERROR - DVR:Recorder: Error 3 (The recording was aborted) starting the record, shutting things down.
Jul 03, 2018 12:32:44.957 [56232] ERROR - DVR:Grabber: Starting media grab failed.
Jul 03, 2018 12:33:44.959 [56232] ERROR - DVR:Recorder: Error 3 (The recording was aborted) starting the record, shutting things down.
Jul 03, 2018 12:33:44.959 [56232] ERROR - DVR:Grabber: Starting media grab failed.
Jul 03, 2018 12:34:12.421 [1580] ERROR - LPE: unknown item 14503.
Jul 03, 2018 12:34:12.421 [1580] ERROR - Versions: failed to generate query for path library://f3f6c4f5-7920-4880-9655-b2f7ba0a880c/item/%2Flibrary%2Fmetadata%2F14503
Jul 03, 2018 12:34:12.421 [1580] ERROR - Versions: skipping items for generator 2671: unable to generate version set query
Jul 03, 2018 12:34:12.421 [1580] WARN - Versions: generator The Incredibles has an empty version set query, assuming generator is no longer valid
Jul 03, 2018 12:34:44.961 [31188] ERROR - DVR:Recorder: Error 3 (The recording was aborted) starting the record, shutting things down.
Jul 03, 2018 12:34:44.961 [31188] ERROR - DVR:Grabber: Starting media grab failed.
Jul 03, 2018 12:35:08.268 [16136] INFO - AutoUpdate: no updates available
Jul 03, 2018 12:35:31.215 [17476] ERROR - [PlexRelay] kex protocol error: type 7 seq 11
Jul 03, 2018 12:35:31.700 [17476] INFO - [PlexRelay] Allocated port 14689 for remote forward to localhost:32401
Jul 03, 2018 12:35:46.837 [16136] ERROR - Exception handled: bad lexical cast: source type value could not be interpreted as target
Jul 03, 2018 12:35:46.868 [20280] ERROR - Exception handled: bad lexical cast: source type value could not be interpreted as target
Jul 03, 2018 12:35:46.883 [17476] ERROR - Exception handled: bad lexical cast: source type value could not be interpreted as target
Jul 03, 2018 12:35:46.915 [20280] ERROR - Exception handled: bad lexical cast: source type value could not be interpreted as target
Jul 03, 2018 12:35:52.179 [20280] ERROR - Exception handled: bad lexical cast: source type value could not be interpreted as target
Jul 03, 2018 12:35:52.195 [16136] ERROR - Exception handled: bad lexical cast: source type value could not be interpreted as target
Jul 03, 2018 12:35:52.226 [17476] ERROR - Exception handled: bad lexical cast: source type value could not be interpreted as target
Jul 03, 2018 12:35:52.242 [16136] ERROR - Exception handled: bad lexical cast: source type value could not be interpreted as target
Jul 03, 2018 12:35:54.694 [56232] ERROR - DVR:Recorder: Error 3 (The recording was aborted) starting the record, shutting things down.
Jul 03, 2018 12:35:54.694 [56232] ERROR - DVR:Grabber: Starting media grab failed.
Jul 03, 2018 12:35:54.928 [16136] ERROR - ClientProfileExtra: video transcode target already exists for streaming hls
Jul 03, 2018 12:35:54.928 [16136] ERROR - PlexClient::downloadContainer: expected MediaContainer element, found html
Jul 03, 2018 12:35:54.928 [16136] ERROR - TranscodeUniversalRequest: unable to get container: /?includeBandwidths=1&offset=-1&X-Plex-Session-Identifier=843CD304-D644-4F1E-BE3F-2C18D4C8F63B
Jul 03, 2018 12:36:42.121 [20280] INFO - AutoUpdate: no updates available
Jul 03, 2018 12:36:44.964 [34236] ERROR - DVR:Recorder: Error 3 (The recording was aborted) starting the record, shutting things down.
Jul 03, 2018 12:36:44.964 [34236] ERROR - DVR:Grabber: Starting media grab failed.
This is the last thing in the Plex Tuner Service log after I closed the channel I was watching from the iPad…
Jul 03, 2018 12:24:09.829 [39288] WARN - [E] http_streamer_t: http write error
Jul 03, 2018 12:24:09.829 [37552] INFO - [I] http_streamer_t::send_thread_func: removing http client
Jul 03, 2018 12:24:09.829 [37552] INFO - [I] http_streamer_t::send_thread_func: all clients are deleted. Setting exit flag
Jul 03, 2018 12:24:09.844 [10104] INFO - [I] streamer_container_t::control_thread. Removed disconnected streamer ed6ff309-ef21-477b-a9be-cc1649cbf2bd
Jul 03, 2018 12:24:09.844 [10104] INFO - [I] streamer_container_t::delete_streamer. Last streamer was deleted. Stop program streamer
Jul 03, 2018 12:24:09.844 [10104] INFO - [I] dvb_program_streamer_t::stop. Stoping program streamer for channel triplet://0:1001:7
Jul 03, 2018 12:24:09.844 [10104] INFO - [I] transponder_streamer::stop_channel. Stop request for channel triplet://0:1001:7
Jul 03, 2018 12:24:09.844 [53304] INFO - [I] CTVSStreamSource::RemoveAllPids. Removing PIDs for client triplet://0:1001:7
Jul 03, 2018 12:24:09.844 [10104] INFO - [I] transponder_streamer::start_idle_timer
Jul 03, 2018 12:24:13.218 [1484] INFO - [I] device_manager_t::idle_timer_func. Stream container for channel triplet://0:1001:7 on device dvb#bda#0#@device:pnp:\\?\pci#ven_14f1&dev_8880&subsys_6a180070&rev_04#6&29bdcbed&0&000800e2#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{9f0e8b90-c677-11db-beb4-00a0c9f21fc7} is idle. Deleting it.
Jul 03, 2018 12:24:19.342 [19764] INFO - [I] Stopping graph
Jul 03, 2018 12:24:19.404 [53304] INFO - [I] StopDevice()
Jul 03, 2018 12:24:19.420 [53304] INFO - [I] stop_graph: hr=0, state=0
Jul 03, 2018 12:24:23.279 [1484] INFO - [I] device_manager_t::idle_timer_func. Device dvb#bda#0#@device:pnp:\\?\pci#ven_14f1&dev_8880&subsys_6a180070&rev_04#6&29bdcbed&0&000800e2#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{9f0e8b90-c677-11db-beb4-00a0c9f21fc7} is idle. Unloading it.
Jul 03, 2018 12:24:23.279 [1484] INFO - [I] transponder_streamer::stop_idle_timer
Jul 03, 2018 12:24:23.279 [1484] INFO - [I] CTVSStreamSource::Term. Waiting for streaming thread to stop
Jul 03, 2018 12:24:23.294 [1484] INFO - [I] CTVSStreamSource::Term. Streaming is stopped
Jul 03, 2018 12:24:23.294 [1484] INFO - [I] CTVSStreamSource::Term. Stream source is stopped
Jul 03, 2018 12:24:23.482 [19764] INFO - [I] transponder_streamer::idle_thread_func finished
Let me know what else you guys need!
