Live TV not showing in Samsung TV
My TV is NU7100 which is 2018 UHD
Live TV menu shows on browser and mobile but not in my samsung TV.
Have read up on everything but no clear understanding.
Also have plex pass. And I believe Live TV has nothing to do with plex server.
Thanks Trial
I thought the 2016+ UHD models supported, but thanks for the update and genuinely hoping plex has the feature released sooner.
Any idea if there is an expected timeline?
Same here. I have an older Samsung TV (2014) that I would like to have the new live streaming TV you just recently released this year (2020). Is there a beta that we can test? Thanks.
If you have a newer Samsung TV that runs tizen you should be able to install the TV plus app which looks like the same channels that were released on Plex.
Afaik it comes preloaded on all newer Samsung TVs and yes it’s free and has a guide and you can type channel numbers with a remote that has numbers and you can use channel up and down on your remote and you can even hit return and it will go to the last channel you were on just like a normal tv experience.
