Is it not possible to watch live TV using the client on the Samsung SmartTV??
Yeah I use it all the time on my Samsung’s
How did you enable it on the Plex client on the Samsung Smart TV? I don’t even see the option.
So its just the 4k TV’s that this will work with??
I own several Samsung TVs (32-65, all series, some 4K, some not) - all of them have workable clients.
So what did you have to change to be able to see the option to view live tv?? I just added the tuner last night, and its all set up on the server, Plex sees it just fine, and has downloaded the guide.
I just don’t know how to view Live TV on the Samsung TV’s
Live TV is only available on the Tizen app. (model years 2016+)
The old Samsung Smarthub app (written by Orca) will not get any further updates and thus, no live tv ability.
Ok, so I believe we have one of those. But where in the Plex app do I find the option to watch Live TV??
If you only have the old Samsungs, you won’t get live TV ability in the Plex app.
I understand that…if I do have one newer than 2016, how does the Live TV option show up in the app?
If you really have a Samsung which has the newer app, you’d notice yourself, because it looks entirely different from the old app.
I have a Tizen model, see screenshot for Live TV. If you don’t see icon on top menu then enable in app settings under Home Screen Media Types.
