Local asset selection priority has changed?
Server Version#: 1.43.0.10467
Running in plexinc/pms-docker on a Debian host.
Player Version#: Any (web. android, android tv)
I have been using plex with Prefer local metadata turned on for years and the behavior has been pretty consistent.
But with one of the latest updates it suddenly changed
For a movie with three local posters named
Is this intentional?
UPDATE:
Its stranger than i initially thought.
If i move poster-1.webp out of the folder containing the movie. Refresh metadata. Then move the poster-1.webp back into the folder and refresh metadata then plex suddenly shows poster-1.webp as the poster.
The same happens if i move poster-2.webp out and back in. poster-2.webp is now suddenly the selected poster.
It appears as if the file last added to the folder is selected regardless of the file numbering.
As an FYI… Prefer local metadata has no effect on posters unless they are embedded into your media. The setting you want is Use local assets which is the one plex uses for local artwork assets.
I’ve also not used multiple assets but looking at the doc https://support.plex.tv/articles/200220677-local-media-assets-movies I wonder if this is preferred …
The doc is a little confusing but maybe both work, poster.webp and/or poster-1.webp
Check my update.
Its broken broken.
If i rename poster-1.webp to poster.webp ti works… but only by accident.
If i rename poster-2.webp to poster-9.webp suddenly poster-9.webp is the active poster even when i still have a file named poster.webp in the folder.
It appears that the last touched file is the one that is selected regardless of file numbering.
In this picture poster-9.webp is the active poster after metadata refresh.
It appears to select based on the Modified Date not the file numbering.
I am using Use local assets
Prefer local metadata is also on and i copied the wrong text to my post by mistake
That makes sense. I’ll try and repro this later as I’m heading out but the thing that might be happening is that the item might be locked in plex. Would you have EVER select poster-9 as the default poster via the plex ux edit function ? If so then it would be considered locked by plex (as you selected it).
One way to check is to open the xml for the movie and search for Field locked and if you see one for thumb (thumb = poster from what I remember). If there is and this is set to 1 then that would explain it.
Nope.
I can rename the poster file to poster-1 or poster-7 or poster-8 and suddenly that file is the one shown after refresh. Rename poster-9 to poster-5 and boom its back to being the favorite.
I have attached the XML.
Only locked field is collection.
453983.zip (14.3 KB)
Also this happens with all my movies. Thunderbolts is just an example.
Could you observe the posters changing their order, after refreshing metadata?
(in the show’s Edit → Poster dialog)
Okay. I wonder if its the timestamps on the files and the way the scanner is detecting them when they change after the rename. Would you happen to have the server setting Run a partial scan when changes are detected enabled ?
I also wondering using something like touch to adjust the files and their times to match what order you are trying to get.
Initial setup
posters are displayed in the correct order 1-2-3 in the edit window. But poster 3 is selected
I rename poster-2 (middel poster) to dummy and then refresh metadata
then i open edit again to see order
poster-3 is still selected and dummy.webp is not in the list. As expected
I then rename dummy back to poster-2 and then refresh metadata
Now poster-2 is the displayed poster and the order is the metadata editor changed.
Poster 1 is first poster-3 second and poster-2 last
If i now rename poster-1 to just poster and refresh metadata
I get the correct poster but new order in the editor again.
Used SSH to my nas and tested
This did not affect the order or the displayed poster.
But renaming poster-1.webp to dummy and back again did changed it to the active poster after a metadata refresh.
mv poster-1.webp dummy
order changed poster-1.webp is now displayed.
my server settings are
I have a synology NAS with the files and a NUC running plex and other docker containers. Plex accesses the files via SMB. The auto detect changes at the top stopped working after i moved plex from the NAS to the NUC but i am pretty sure that is a limitation related to smb. So i turned it off.
disabling Run a partial scan when changes are detected does not appear to fix anything.
I can post my docker compose if its relevant?
I played a bit more.
It does not appear directly linked to timestamps
before this poster-1 was displayed
after this and a metadata refresh poster-2 is displayed
I’m at a loss to explain it. Last shot in the dark from me is does a plex dance of the files help? Just the posters.
Maybe as it’s only a rename and the file itself is not changed (checksum) plex is remapping the files internally in the db when you rename them. Total speculation …
Lets see if someone else has an idea.
I will be writing up an internal bug report.
Could you
  • enable server debug logging (NOT “verbose” logging)
  • stop and restart the Plex server
  • reproduce the erroneous behaviour
  • fetch server logs immediately afterwards, and attach them here or send them to me directly per PM
Tried first with just posters and then with the folder the movie is in.
Did not fix anything.
(i have loads of other movies with the same problem after a metadata scan of the full library.)
OK
  1. Renamed poster-1 to poster and refreshed metadata for the movie to ensure the correct poster was displayed.
  2. enabled logging
  3. restarted plex docker container
  4. renamed poster-3 to poster 4
  5. refreshed metadata again
  6. observed the displayed poster is now poster-4
  7. downloaded logs
Full zip file upload
Plex Media Server Logs_2026-02-04_18-15-48.zip (109.0 KB)
I am guessing Plex Media Scanner Matcher.log is the relevant file
Feb 04, 2026 18:15:39.733 [139754341915392] INFO - Plex Media Scanner v1.43.0.10467-2b1ba6e69 - Docker Docker Container x86_64 - build: linux-x86_64 - GMT 01:00
Feb 04, 2026 18:15:39.734 [139754341915392] INFO - Linux version: 6.12.63+deb13-amd64, language: en-US
Feb 04, 2026 18:15:39.734 [139754341915392] INFO - Processor: 18-core Intel(R) Core(TM) Ultra 5 125H
Feb 04, 2026 18:15:39.734 [139754341915392] INFO - /usr/lib/plexmediaserver/Plex Media Scanner --match --type 1 --log-file-suffix  Matcher --item 454386 --content-type=application/json --match-tag-mode=all
Feb 04, 2026 18:15:39.734 [139754342432512] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.39.4, threadsafe=1
Feb 04, 2026 18:15:39.788 [139754342432512] DEBUG - Matcher: found 7 auxiliary files for Thunderbolts*
Feb 04, 2026 18:15:39.788 [139754342432512] DEBUG - Matcher: no sidecar subtitle files found for /data/video/Movies/4K Ultra HD/Thunderbolts (2025)/Thunderbolts (2025).mkv
Feb 04, 2026 18:15:39.788 [139754342432512] DEBUG - Scanner: found local media asset "/data/video/Movies/4K Ultra HD/Thunderbolts (2025)/background-2.webp"
Feb 04, 2026 18:15:39.788 [139754342432512] DEBUG - Scanner: found local media asset "/data/video/Movies/4K Ultra HD/Thunderbolts (2025)/background-3.webp"
Feb 04, 2026 18:15:39.788 [139754342432512] DEBUG - Scanner: found local media asset "/data/video/Movies/4K Ultra HD/Thunderbolts (2025)/background-1.webp"
Feb 04, 2026 18:15:39.788 [139754342432512] DEBUG - Scanner: found local media asset "/data/video/Movies/4K Ultra HD/Thunderbolts (2025)/poster-2.webp"
Feb 04, 2026 18:15:39.788 [139754342432512] DEBUG - Scanner: found local media asset "/data/video/Movies/4K Ultra HD/Thunderbolts (2025)/poster.webp"
Feb 04, 2026 18:15:39.788 [139754342432512] DEBUG - Scanner: found local media asset "/data/video/Movies/4K Ultra HD/Thunderbolts (2025)/poster-4.webp"
No idea why it decides that poster-4.webp should be selected
