Hello there
I’ve got a problem with my plex install on my raspberry pi 4 (4GB). The newest version, which I’ve downloaded directly, is installed on the server. The setup was fairly easy without any problem. After the setup, my media was scanned and everything was working as expected. This was like three weeks ago. It worked for a short period and then it was «offline».
The main problem is that the server sometimes is online but not even reachable from my home network! Currently it can’t be reached from «the outside», but in the settings it’s showing that it is reachable over the internet. I have reinstalled Plex allready but without any success. Furthermore I’ve seen that when I restart the Plex-Mediaserver it is reachable over the internet, but when someone actually is trying to connect, it imidiently swiches to «can’t connect over the internet»!
Does anybody here have a idea where to start fixing this issue? Which log files do you need to check?
I also noticed something special: I tryed to connect with my mobile connection to my Plex libary. It worked and I could play a video for like 2 minutes without a problem, but in the server settings the show that i canno’t connect to “the outside”.
