Server Version#: latest
Player Version#: web/iOS
I’m having problems with my plex server, it worked perfectly fine for about 3 months, and then my server started randomly losing connection when updating the library’s, I thought it was folder structure so I split most movies off so it didn’t have to update 1tb+ on a single disk, still the same problem, the server goes unresponsive to a degree that local host even is unreachable, closing down the server and starting it again doesn’t work, I have to do a full system restart…
And now it’s losing connection even at idle, and yes, power settings are set so it doesn’t sleep.
I’ve tried: reinstalling windows, the server software, made a small library on a SSD, same problem.
The server is hosted on a 3rd gen i7 @ 4.5Ghz, with 16gb of ram, so It shouldn’t be a hardware problem.
Hoping to get some helpful inputs.
Kind regards
Thomas
