Local PLEX ip address does not work
Hello!! for some time I use plex on my nas ds918 + it worked.
there is little I added a router asus rt-ac88u with a vpn (expressvpn) and also (nordvpn) tests which not nothing, give good, rather its did not suit me.
so I send everything back as well as the subscriptions.
the router and the vpn (1 each time) (the vpn was in the asus router) its worked (ms not fast enough).
since without router nor vpn when I try to connect to plex without docker, from my computer which is on the same network as the nas, to enter the ip address (my ip address: 32400) the web page gives me an error:
This page does not work
my ip address did not send any data.
ERR_EMPTY_RESPONSE
before its no longer works i had a port forwarding error (i deleted is reinstalling plex server on the nas and remade all my libraries. nothing to change)
I can connect to plex through http / :: plex.tv/desktop, it works but only with my username and this with several PCs… I wanted to create a remote connection with a friend and it gives me an error from the Server
with my username I can log in from the outside
I hope you will understand this because I have trouble finding the breakdown
thank you for the time taken and thank you for your answers!
I’m sorry, I tried to understand what you wrote but I’m just unable to. What you wrote is too confusing . Try re-wording it. Good luck
